Error when exporting Onnx model "NOT IMPLEMENTED: Order of dimensions of input cannot be interpreted"
Fra_
I am currently using the STM32 Edge AI Developer Cloud to convert my ONNX model, which I built using PyTorch.
The ONNX model is attached for your reference.
I would greatly appreciate your guidance on this matter, as it is blocking my research.
Thank you for your assistance.
hamitiya
We are aware of a similar issue, and it will be fixed in our next release of ST Edge AI Developer Cloud.
Best regards,
Yanis
3 REPLIES 3
hamitiya
Best regards,
Yanis
I think this issue is also in X-CUBE-AI, right?
Sorry for late reply, yes this issue is also in X-CUBE-AI since they both rely on the same command-line. They both will be updated with new command line interface which will fix the problem you raised.
Best regards,
Yanis
