2024-12-31 6:25 AM
Im doing a proof-of-concept on trying to run a model on the STM32N6 that does object-detection.
For this, Im following this guide: https://github.com/STMicroelectronics/stm32ai-modelzoo-services/blob/main/object_detection/src/training/README.md
1. `!git clone https://github.com/STMicroelectronics/stm32ai-modelzoo-services.git`
2. `!pip install -r stm32ai-modelzoo-services/requirements.txt`
3. Im using a Pascal VOC XML dataset which Im converting using the provided scripts with the different config files as attachment in a zip-file
4. `!python converter.py --config-name dataset_config_train.yaml`
5. `!python converter.py --config-name dataset_config_validation.yaml`
6. `!python dataset_create_tfs.py --config-name dataset_config_tfs.yaml`
7. `!python stm32ai_main.py`
This gives the following error (full stacktrace as attachment): `ValueError: Can't convert Python sequence with mixed types to Tensor.`.
As I believe Im following the steps correctly, Im unsure what Im missing to correctly train this model?
2025-02-10 7:17 AM - edited 2025-02-10 7:18 AM
Hello @milanvdm ,
I did not reproduce your error.
I started from zero and here is what I did so you can follow along:
ST MODEL ZOO INSTALL:
First, I installed ST Model Zoo services doing this:
Make sure to use a virtual env as it can be sources of errors.
CREATE A DATASET FROM VOC FORMAT:
Then I took your data which is inside the folder /voc and splitted into /train and /validation.
I copied this folder in /object_detection/datasets/
Then I edited the dataset_config.yaml in dataset_converter:
dataset:
format: pascal_voc_format
class_names: [vehicle,license_plate]
coco_format:
images_path: ../chess_coco/train
json_annotations_file_path: ../chess_coco/train/_annotations.coco.json
export_dir: subset_chess/train
pascal_voc_format:
images_path: ../voc/train
xml_files_path: ../voc/train
export_dir: ../converted_voc/train
hydra:
run:
dir: outputs/${now:%Y_%m_%d_%H_%M_%S}
(make sure to activate the virtual env before running any command).
With this, you should have in /converted_voc/train jpg files and txt files.
You can do the same for your validation data
Next, we use the create_tfs scripts:
dataset:
dataset_name: test_voc
training_path: ../converted_voc/train
validation_path: ../converted_voc/validation
test_path:
settings:
max_detections: 20
hydra:
run:
Now you should have .tfs files with your jpg and txt files.
USING ST MODEL ZOO
Next is using model zoo:
Then edit the ssd_mobilenet_v2_fpnlite_035_192_config.yaml:
This should work.
If this worked, you are free to change anything to do what you planned to do.
To use the N6, you will need to download the getting started here:
https://www.st.com/en/development-tools/stm32n6-ai.html
And follow this: https://github.com/STMicroelectronics/stm32ai-modelzoo-services/blob/main/object_detection/deployment/README_STM32N6.md
Have a good day,
Julian
2025-01-03 1:07 AM
Could you please share your installed python packages using :
!pip list
2025-01-03 3:43 AM
Package Version
absl-py 2.1.0
alembic 1.14.0
antlr4-python3-runtime 4.9.3
appdirs 1.4.4
archspec 0.2.2
astunparse 1.6.3
audioread 3.0.1
blinker 1.9.0
boltons 23.1.1
Brotli 1.1.0
cachetools 5.5.0
certifi 2024.12.14
cffi 1.16.0
charset-normalizer 3.3.2
click 8.1.8
cloudpickle 2.2.1
cmaes 0.11.1
colorama 0.4.5
coloredlogs 15.0.1
colorlog 6.9.0
conda 23.11.0
conda-libmamba-solver 23.12.0
conda-package-handling 2.2.0
conda_package_streaming 0.9.0
contourpy 1.3.1
cycler 0.12.1
databricks-cli 0.18.0
decorator 5.1.1
distro 1.8.0
docker 6.1.3
entrypoints 0.4
Flask 2.3.3
flatbuffers 2.0.7
fonttools 4.55.3
gast 0.6.0
gitdb 4.0.12
GitPython 3.1.44
google-auth 2.37.0
google-auth-oauthlib 0.4.6
google-pasta 0.2.0
greenlet 3.1.1
grpcio 1.68.1
gunicorn 20.1.0
h5py 3.12.1
humanfriendly 10.0
hydra-core 1.3.2
idna 3.6
imageio 2.36.1
imgaug 0.4.0
importlib-metadata 6.11.0
itsdangerous 2.2.0
Jinja2 3.1.5
joblib 1.2.0
jsonpatch 1.33
jsonpointer 2.4
keras 2.8.0
Keras-Preprocessing 1.1.2
kiwisolver 1.4.8
larq 0.13.3
lazy_loader 0.4
libclang 18.1.1
libmambapy 1.5.5
librosa 0.10.0.post2
llvmlite 0.43.0
Mako 1.2.4
mamba 1.5.5
Markdown 3.7
MarkupSafe 3.0.2
marshmallow 3.20.1
matplotlib 3.6.2
menuinst 2.0.1
mlflow 2.3.0
mpmath 1.3.0
msgpack 1.1.0
munch 2.5.0
networkx 3.4.2
numba 0.60.0
numpy 1.23.4
nvidia-cublas-cu11 11.11.3.6
nvidia-cudnn-cu11 8.6.0.163
oauthlib 3.2.2
omegaconf 2.3.0
onnx 1.12.0
onnxconverter-common 1.13.0
onnxruntime 1.15.1
opencv-python 4.6.0.66
opt_einsum 3.4.0
optuna 3.1.1
packaging 23.2
pandas 1.5.3
pillow 11.1.0
pip 23.3.2
platformdirs 4.1.0
pluggy 1.3.0
pooch 1.6.0
protobuf 3.19.6
pyarrow 11.0.0
pyasn1 0.6.1
pyasn1_modules 0.4.1
pycosat 0.6.6
pycparser 2.21
PyJWT 2.10.1
pyparsing 3.2.1
pyserial 3.5
PySocks 1.7.1
python-dateutil 2.9.0.post0
pytz 2023.4
PyYAML 6.0.2
querystring-parser 1.2.4
requests 2.28.2
requests-oauthlib 2.0.0
rsa 4.9
ruamel.yaml 0.18.5
ruamel.yaml.clib 0.2.7
scikit-image 0.24.0
scikit-learn 1.2.2
scipy 1.13.1
seaborn 0.12.2
setuptools 68.2.2
shapely 2.0.6
six 1.17.0
skl2onnx 1.14.0
smmap 5.0.2
soundfile 0.13.0
soxr 0.5.0.post1
SQLAlchemy 2.0.36
sqlparse 0.5.3
sympy 1.13.3
tabulate 0.9.0
tensorboard 2.8.0
tensorboard-data-server 0.6.1
tensorboard-plugin-wit 1.8.1
tensorflow 2.8.3
tensorflow-estimator 2.8.0
tensorflow-io-gcs-filesystem 0.37.1
termcolor 2.5.0
terminaltables 3.1.10
tf2onnx 1.14.0
threadpoolctl 3.5.0
tifffile 2024.12.12
tqdm 4.65.0
truststore 0.8.0
typing_extensions 4.12.2
urllib3 1.26.13
websocket-client 1.8.0
Werkzeug 3.1.3
wget 3.2
wheel 0.42.0
wrapt 1.17.0
xmlrunner 1.7.7
zipp 3.21.0
zstandard 0.22.0
2025-01-18 11:37 AM
@MCHTO.1 Just checking in if you were able to reproduce this issue we are facing or if you would need more information?
2025-02-10 1:57 AM - edited 2025-02-10 1:57 AM
@MCHTO.1 Kind reminder as our STM32N6 DK arrived today but we are still blocked on this issue as we cannot train the model on our own data.
2025-02-10 2:34 AM
Hello @milanvdm ,
Can you link me where you found your dataset, I will try to reproduce on my side.
Have a good day,
Julian
2025-02-10 2:51 AM
@Julian E. Its not a public dataset but I will create a public Google Colab and try to reproduce it with a public dataset!
2025-02-10 3:35 AM
Google Colab has stopped supporting Tensorflow versions <2.12 so I could not fully test this out (might be worth looking into upgrading to a higher TF in that case!).
Ive attached a zip file with the Colab script and a public dataset. Hopefully this can help you reproduce the issue. Let me know if you would need more information!
Hello @milanvdm ,
dataset:
coco_format:
pascal_voc_format:
hydra:
run:
dataset:
test_path:
settings:
max_detections: 20
hydra:
run:
USING ST MODEL ZOO
This should work.
Have a good day,
Julian
2025-02-13 1:20 AM - edited 2025-02-13 1:36 AM
I'm using ubuntu environment. After installing the conda environmen environment according to the wiki, I used the same dataset and path, and reported an error after running converter.py, as shown in the figure below. How to solve it?
You can reproduce the problem after pip install -r requirements.txt and run python converter.py dataset_config.yaml.
I found a typo, python is not pyhton.
