2024-12-31
6:25 AM
- last edited on
2025-06-17
2:32 AM
by
Lina_DABASINSKA
Im doing a proof-of-concept on trying to run a model on the STM32N6 that does object-detection.
For this, Im following this guide: https://github.com/STMicroelectronics/stm32ai-modelzoo-services/blob/main/object_detection/src/training/README.md
1. `!git clone https://github.com/STMicroelectronics/stm32ai-modelzoo-services.git`
2. `!pip install -r stm32ai-modelzoo-services/requirements.txt`
3. Im using a Pascal VOC XML dataset which Im converting using the provided scripts with the different config files as attachment in a zip-file
4. `!python converter.py --config-name dataset_config_train.yaml`
5. `!python converter.py --config-name dataset_config_validation.yaml`
6. `!python dataset_create_tfs.py --config-name dataset_config_tfs.yaml`
7. `!python stm32ai_main.py`
This gives the following error (full stacktrace as attachment): `ValueError: Can't convert Python sequence with mixed types to Tensor.`.
As I believe Im following the steps correctly, Im unsure what Im missing to correctly train this model?
2025-02-13 1:25 AM
It looks like you have a typo after modifying the yaml file.
Can you share your yaml file.
Regards.
2025-02-13 5:21 AM - edited 2025-02-13 5:26 AM
It's the yaml file.
I don’t think it’s a problem with the yaml file. I used the original file on github and got the same error. You can reproduce this issue according to the above steps(ubuntu conda environment).
