Error training object_detection using model-zoo-services
milanvdm
Im doing a proof-of-concept on trying to run a model on the STM32N6 that does object-detection.
For this, Im following this guide: https://github.com/STMicroelectronics/stm32ai-modelzoo-services/blob/main/object_detection/src/training/README.md
1. `!git clone https://github.com/STMicroelectronics/stm32ai-modelzoo-services.git`
2. `!pip install -r stm32ai-modelzoo-services/requirements.txt`
3. Im using a Pascal VOC XML dataset which Im converting using the provided scripts with the different config files as attachment in a zip-file
4. `!python converter.py --config-name dataset_config_train.yaml`
5. `!python converter.py --config-name dataset_config_validation.yaml`
6. `!python dataset_create_tfs.py --config-name dataset_config_tfs.yaml`
7. `!python stm32ai_main.py`
This gives the following error (full stacktrace as attachment): `ValueError: Can't convert Python sequence with mixed types to Tensor.`.
As I believe Im following the steps correctly, Im unsure what Im missing to correctly train this model?
3 REPLIES 3
MCHTO.1
Could you please share your installed python packages using :
!pip list
Package                      Version
absl-py                      2.1.0
alembic                      1.14.0
antlr4-python3-runtime       4.9.3
appdirs                      1.4.4
archspec                     0.2.2
astunparse                   1.6.3
audioread                    3.0.1
blinker                      1.9.0
boltons                      23.1.1
Brotli                       1.1.0
cachetools                   5.5.0
certifi                      2024.12.14
cffi                         1.16.0
charset-normalizer           3.3.2
click                        8.1.8
cloudpickle                  2.2.1
cmaes                        0.11.1
colorama                     0.4.5
coloredlogs                  15.0.1
colorlog                     6.9.0
conda                        23.11.0
conda-libmamba-solver        23.12.0
conda-package-handling       2.2.0
conda_package_streaming      0.9.0
contourpy                    1.3.1
cycler                       0.12.1
databricks-cli               0.18.0
decorator                    5.1.1
distro                       1.8.0
docker                       6.1.3
entrypoints                  0.4
Flask                        2.3.3
flatbuffers                  2.0.7
fonttools                    4.55.3
gast                         0.6.0
gitdb                        4.0.12
GitPython                    3.1.44
google-auth                  2.37.0
google-auth-oauthlib         0.4.6
google-pasta                 0.2.0
greenlet                     3.1.1
grpcio                       1.68.1
gunicorn                     20.1.0
h5py                         3.12.1
humanfriendly                10.0
hydra-core                   1.3.2
idna                         3.6
imageio                      2.36.1
imgaug                       0.4.0
importlib-metadata           6.11.0
itsdangerous                 2.2.0
Jinja2                       3.1.5
joblib                       1.2.0
jsonpatch                    1.33
jsonpointer                  2.4
keras                        2.8.0
Keras-Preprocessing          1.1.2
kiwisolver                   1.4.8
larq                         0.13.3
lazy_loader                  0.4
libclang                     18.1.1
libmambapy                   1.5.5
librosa                      0.10.0.post2
llvmlite                     0.43.0
Mako                         1.2.4
mamba                        1.5.5
Markdown                     3.7
MarkupSafe                   3.0.2
marshmallow                  3.20.1
matplotlib                   3.6.2
menuinst                     2.0.1
mlflow                       2.3.0
mpmath                       1.3.0
msgpack                      1.1.0
munch                        2.5.0
networkx                     3.4.2
numba                        0.60.0
numpy                        1.23.4
nvidia-cublas-cu11           11.11.3.6
nvidia-cudnn-cu11            8.6.0.163
oauthlib                     3.2.2
omegaconf                    2.3.0
onnx                         1.12.0
onnxconverter-common         1.13.0
onnxruntime                  1.15.1
opencv-python                4.6.0.66
opt_einsum                   3.4.0
optuna                       3.1.1
packaging                    23.2
pandas                       1.5.3
pillow                       11.1.0
pip                          23.3.2
platformdirs                 4.1.0
pluggy                       1.3.0
pooch                        1.6.0
protobuf                     3.19.6
pyarrow                      11.0.0
pyasn1                       0.6.1
pyasn1_modules               0.4.1
pycosat                      0.6.6
pycparser                    2.21
PyJWT                        2.10.1
pyparsing                    3.2.1
pyserial                     3.5
PySocks                      1.7.1
python-dateutil              2.9.0.post0
pytz                         2023.4
PyYAML                       6.0.2
querystring-parser           1.2.4
requests                     2.28.2
requests-oauthlib            2.0.0
rsa                          4.9
ruamel.yaml                  0.18.5
ruamel.yaml.clib             0.2.7
scikit-image                 0.24.0
scikit-learn                 1.2.2
scipy                        1.13.1
seaborn                      0.12.2
setuptools                   68.2.2
shapely                      2.0.6
six                          1.17.0
skl2onnx                     1.14.0
smmap                        5.0.2
soundfile                    0.13.0
soxr                         0.5.0.post1
SQLAlchemy                   2.0.36
sqlparse                     0.5.3
sympy                        1.13.3
tabulate                     0.9.0
tensorboard                  2.8.0
tensorboard-data-server      0.6.1
tensorboard-plugin-wit       1.8.1
tensorflow                   2.8.3
tensorflow-estimator         2.8.0
tensorflow-io-gcs-filesystem 0.37.1
termcolor                    2.5.0
terminaltables               3.1.10
tf2onnx                      1.14.0
threadpoolctl                3.5.0
tifffile                     2024.12.12
tqdm                         4.65.0
truststore                   0.8.0
typing_extensions            4.12.2
urllib3                      1.26.13
websocket-client             1.8.0
Werkzeug                     3.1.3
wget                         3.2
wheel                        0.42.0
wrapt                        1.17.0
xmlrunner                    1.7.7
zipp                         3.21.0
zstandard                    0.22.0
milanvdm
@MCHTO.1 Just checking in if you were able to reproduce this issue we are facing or if you would need more information?
