Error 200 and error 801 Validate on target on STM32F4291-DISCO
LMart.12
I'm a newcomer in the STM32 machine learning world and I tried to make a AI model work on my STM32F429I-DISCO. Unfortunately the "Validate on target" option does not work... Errors are E200 and E801. Here is my thought process :
Iinstall a ftdi to my board to send data trough serial port : 0693W00000NstnmQAB.jpgThen I launch stm32cube mx, select the board STM32F429I-DISC1 and start project without initialize all peripheral with their default mode. Then :
0693W00000NsttGQAR.png0693W00000NsttWQAR.png0693W00000NstXlQAJ.png0693W00000NstxmQAB.pngAnd finally :
0693W00000NstzxQAB.pngI also tried validate on target on my other COM (COM4) and with communication port on the target : USART 1.
Each time I get the same result :
0693W00000Nsu2NQAR.pngI don't know what to do, can someone know the solution of my problem ?
Thank in advance !
Best regards,
Martin
20 REPLIES 20
I write a quick program and visibly the communication is working both ways :
0693W00000Nt2fmQAB.pngSo the problem must be from X-Cube-AI or STM32CubeMX.
Regards,
Martin
