2024-04-16 03:51 AM
Hi, I have a STEVAL-STWINKT1B that I am using to log data into my PC with HSDPython_SDK.
How can I set the accelerometer range (for example IIS3DWB to 16g)?
Ivan
2024-12-10 05:26 AM
Hey, you can use the app "ST BLE Sensor" to connect to the STEVAL-STWINKT1B and change the parameters of the different sensors. In particular, you can change the full-scale parameter of the IIS3DWB sensor.
