Support to connect SPC5-UDESTK Debugger
Options
‎2024-02-13 04:46 AM
Hi Everyone,
I'm working with a SPC570S discovery board. I uploaded a code with my SPC5-UDESTK debugger and the codes were successfully uploaded. But suddenly I couldn't upload any code using that, and its green LED still works. But I tested the same code with another similar SPC5-UDESTK debugger and it worked. I checked my SPC5-UDESTK debugger with other development boards also. Unfortunately, it is not working but its green LED is working. Please help me to sort this issue out.
Yohan
Labels:
- Labels:
SPC5 Automotive MCUs
Options
‎2024-04-16 06:27 AM
green LED means that UDESTK is powered.
For connection, please check the orange LED, while red LED is flashing on data transfer from PC to board.
Best Regards,
1 REPLY 1
Options
Best Regards,
