SPC5Studio 3.5.0 is available
Erwan YVIN
Posted on June 09, 2015 at 14:29
Dear All ,
SPC5Studio 3.5.0 is available.
*** Highlights ***
- New SPC5-RLA components set for P-line MCU (with sample applications).
  SPC5-RLA provides ''Register Level Access'' to the MCU, in order to create a
  register oriented application.
  Four modes are possible:
  * Registers setup
  * Registers setup & interrupts
  * Registers setup, interrupts & GPIO (with pinmap wizard)
  * Registers setup, interrupts, GPIO & LLD
- Windows 8 support
- Official eclipse.org Market place plugin
- New organization of features to prepare eclipse Market place integration
*** Notes ***
- Make sure to read the SPC5Studio Users Guide and Components Writers Guide in
  the help section.
http://www.st.com/web/en/catalog/tools/FM147/CL1794/SC1809/PF255702?s_searchtype=keyword
Enjoy SPC5Studio,
The SPC5Studio Team.
4 REPLIES 4
ssk
Posted on June 10, 2015 at 11:00
Hello Erwan,
What is the procedure to download the latest release? I tried Help->Check for Updates but it shows that 'no updates available'. Please provide the steps to upgrade it.
Mike.
Erwan YVIN
Posted on June 10, 2015 at 11:17
Hello Mike ,
It is a new installer
You can download it  on the ST Web page. (~600 MB)
The download section is in the bottom of the page.
i recommend you to save your old applications before installing SPC5Studio 3.5
and to reimport it in SPC5Studio 3.5
       Best regards
                    Erwan
ssk
Posted on June 10, 2015 at 11:40
Appreciate Erwan for quick reply.
Couple of queries,
1. Regarding the saving the old applications, is there any specific settings/configurations that need to be saved? Or is it a regular saving of project?
2. Regarding importing the old project, again any special steps to be carried out or it is just as simple as in current version?
3. Regarding the HighTec C license, will the old license file still work or is it required to acquire new license?
Look forward for quick reply before proceeding to new installation. Thanks.
Mike.
Erwan YVIN
Posted on June 10, 2015 at 15:34 Hello Mike , 1- You can export your project by ''Export'' menu on eclipse. if you save regularly your configuration.xml and your source code. the export should contain all your project. 2- The HAL (Hardware Abstraction Layer) is similar with 3.4.5. After reimporting , you should regenerate the project you can follow ''
How to Import and export projects in SPC5Studio.pdf'' contained in the zip file.
3- The license should work .. the license is located in the directory c:\SPC5Studio\licenses Please follow carrefully the README-FIRST
Installation content
*README-FIRST.txt : This file
*SPC56 Toolchain_overview.pdf : Presentation of the SPC5Studio tool chain
*SPC5Studio v3.5.exe : Spc5studio installer
*SPC5Studio_installation_procedure.docx : Installation procedure of SPC5Studio
*FTDI_Installation_driver_on_SPC560X_Discovery_board.docx : Installation procedure of FTDI driver
and COM port for SPC560x Discovery board
*''How to Import and export projects in SPC5Studio.pdf'' : Procedure to export Old project before
removing old SPC5Studio installation (if any)
*Release Notes.txt : Release notes of latest SPC5Studio release.
How to install ?
- Open first the ''SPC56 Toolchain_overview.pdf'' document and download Universal debuger(UDE) if needed.
- If you are already using SPC5Studio, please save all your existing projects exporting all your all project following
- Follow ''SPC5Studio_installation_procedure.docx'' instructions.
- Follow FTDI installation procedure to enable JTAG debug and serial port.
- Once SPC5Studio properly installed import your existing projects previously saved.
SPC5Studio is based on LUNA Eclipse (Faster and more efficient.) Best regards Erwan
