2022-01-17 3:17 AM
In our project, we are using a 20Mhz external crystal oscillator. The default frequency of external oscialltor in SPC5 Studio CLock Tree editor is 40Mhz. How will I change it to 20Mhz? Please see the picture below.
Br,
Sreejith
2022-01-17 5:29 AM
click on Clock Component:
then on oscillator setting in outline:
You will reach the oscillator settings in the main window:
Then change it to 20 MHz and you will have to adapt all your clock tree using reference manual according to your new external clock.
Best Regards,
-Olivier
2022-01-17 5:29 AM
Best Regards,
-Olivier
2022-01-27 11:54 PM
did it work as you expected ?
Best Regards,
-Olivier
2022-01-28 1:16 AM
Hi Olivier,
I am successful in changing the external clock value as you suggested. But, I am running into trouble with the clock tree configuration.
Best regards,
Sreejith
2022-01-28 2:07 AM
Thank you,
then would you please tag as "best answer" my answer to this topic.
And enter a new topic for your new issue/question.
Best Regards,
-Olivier
