SPC58xxx - How to change the frequency of external oscillator in SPC5 Studio Clock Tree editor?
SKara.7
In our project, we are using a 20Mhz external crystal oscillator. The default frequency of external oscialltor in SPC5 Studio CLock Tree editor is 40Mhz. How will I change it to 20Mhz? Please see the picture below.
Br,
Sreejith
ODOUV.1
click on Clock Component:
then on oscillator setting in outline:
0693W00000JMEOqQAP.pngYou will reach the oscillator settings in the main window:
Then change it to 20 MHz and you will have to adapt all your clock tree using reference manual according to your new external clock.
Best Regards,
-Olivier
4 REPLIES 4
ODOUV.1
Best Regards,
-Olivier
ODOUV.1
did it work as you expected ?
Best Regards,
-Olivier
SKara.7
Hi Olivier,
I am successful in changing the external clock value as you suggested. But, I am running into trouble with the clock tree configuration.
Best regards,
Sreejith
ODOUV.1
Thank you,
then would you please tag as "best answer" my answer to this topic.
And enter a new topic for your new issue/question.
Best Regards,
-Olivier
