2020-11-09 03:20 AM
2020-11-13 07:22 AM
Please have a look at SPC5Studio PWM demos.
Just for info:
SPC582B: PWM is generated using eMIOS
SPC584B: PWM is generated using eMIOS
SPC58EC: PWM is generated using eMIOS
SPC58xG: PWM is generated using eMIOS
SPC58xE: PWM is generated using GTM (install GTM plugin)
SPC58NN: PWM is generated using GTM (install GTM plugin)
Giuseppe
2020-11-13 09:06 AM
Hi Giuseppe.
Thanks an example installed in the SPC5 Studio "SPC58ECxx_RLA PWM-ICU Test Application" the pwm took place in my evaluation board.
SPC5 studio setting and main.c code as well, are now perfect clear.
Thank you.
Santino
