SPC58Ex PWM setting. Someone could me help with a SPC5 Studio setup and code as well?
SGeno.1
Giuseppe DI-GIORE
Please have a look at SPC5Studio PWM demos.
Just for info:
SPC582B: PWM is generated using eMIOS
SPC584B: PWM is generated using eMIOS
SPC58EC: PWM is generated using eMIOS
SPC58xG: PWM is generated using eMIOS
SPC58xE: PWM is generated using GTM (install GTM plugin)
SPC58NN: PWM is generated using GTM (install GTM plugin)
Giuseppe
SGeno.1
Hi Giuseppe.
Thanks an example installed in the SPC5 Studio "SPC58ECxx_RLA PWM-ICU Test Application" the pwm took place in my evaluation board.
SPC5 studio setting and main.c code as well, are now perfect clear.
Thank you.
Santino
