2025-03-11 8:05 AM
i have used PLS many time and many.
Now PLS does not work any more. Still this problem:
Message from component 'PpcJtagTargIntf' :
Can't connect target !
No JTAG client found !
Please check:
- target power supply
- JTAG cable connection
- target configuration
I have done in folder
C:\Program Files (x86)\pls\UDE Starterki5.2\Driver\JtagUsbDriver
with with Administrative rights UninstallPlsUsbJtagDriver.bat and then InstallPlsUsbJtagDriver.bat
I have load VCP for all combination:
only on SPCxxxA , only on SPCxxxB, both on SPCxxxA and SPCxxxB or no VCP.
I have both version on UDE STK 2021 64bit and SPC5-UDESTK 5.02.04.
I have 2 PLS and many boards (both custom and official discovery SPC56).
I try to change laptop but still the same
Never lucky.
Please can somebody help me!!
Thank you in advantages!
2025-03-11 9:25 AM
I have solved the problem.
With a third PC i see that PLS was working and in the "Detail Tab" all was egual to my pc except for "INF Name"
The working PC has "oem30.inf" and not working PC has " oem176.inf"
So after some google search i found these link:
So i have done:
Then i have re-install the PLS drivers and it works again!!
My god...
I hope this help somebody
CK
2025-03-11 9:25 AM
So i have done:
My god...
CK
2025-03-12 12:40 AM
News,
Today i start my laptop, plug pls to program and.. NOT WORKING AGAIN!
Can please somebody fix this problem? I am the only one?
Again i have done in powershell:
pnputil /delete-driver oem4.inf /uninstall /force
and after restart, i have install C:\Program Files (x86)\pls\UDE Starterkit 5.2\Driver\JtagUsbDriver and activate VCP on SPCxxB.
ST Employees have you some tips or fix?
Thank you
CK
