2020-01-22 06:44 AM
I am able to switch between the banks. But writing a software in the banks is failure one.
2020-01-28 07:23 AM
Hello Rama ,
i think that you should update the linker file (application.ld)
Did you use SPC5 Studio ?
Which debugger do you use ?
Best regards
Erwan
2020-01-28 07:23 AM
Hello Rama ,
Best regards
Erwan
2020-01-29 12:28 AM
Hello Erwan,
Thanks for coming back. I am using SPC5 Studio only and i am isystems debugger. I tried changing the Linker script(application.ld) even though there is no use. Any leads will help me
