FreeRTOS port on the SPC, I think there is a problem
guo qiang
Senior
Posted on November 17, 2017 at 04:34
If the kernel need to switch task in the SystemTick(PIT0)ISR,  this should be to trigger a SystemCall.
STM32 PORT:
the vTaskSwitchContext function only made some judgments, to modify pxCurrentTCB, and did not do the task switch.
Yvin.Erwan.001
null
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
guo qiang
Senior
Posted on November 17, 2017 at 04:39
I modified the code:
But I found that there is no task will not switch
2 REPLIES 2
guo qiang
Senior
Erwan YVIN
Posted on November 17, 2017 at 09:26
Hello Guo ,
I am submitting an ER on FreeRTOS components part.
Thank you for sharing your findings ;)
   Best Regards
             Erwan
