Autodevkit Studio BMS Library Functions
Vipuls
Hey Community!
I am trying to build a BMS for a 333V Battery using AEK-MCU-C4MLIT1 as the Master MCU, AEK-COM-ISOSPI1 as the translator and multiple AEK-POW-BMS63EN boards in a daisy chain.
Although there are various examples provided in the SPC5Studio that one can use to get started with the BMS System. However, I am still finding it difficult to use the API functions effectively. I feel that although there are a lot of functions available in the API, their definitions are still absent in the documentation.
Is there any other documentation which one can read to understand the data structures and different functions present in the API for the AEK-POW-BMS63EN?
Thanks,
Vipul
1 REPLY 1
Max VIZZINI
The User Manual is here:
https://www.st.com/resource/en/user_manual/um3185-getting-started-with-autodevkit-battery-management-system-bms-evaluation-boards-stmicroelectronics.pdf
In you your case. the best example to start with is the CHAIN one single or dual access:
Best Regards,
AutoDevKit Team
