AEK-POW_BMS63EN : Fault pin is not being high
bitBuddy
Dear Community members,
In an SPC582b-discovery example code, i modified configuration to set over voltage threshold 3.4 v. While
all the cells in stack is over than 3.4 but the Fault pin in board is not being high.
bitBuddy
1 REPLY 1
Max VIZZINI
Please use the BMSCHAIN driver examples.
Best Regards,
AutoDevKit Team
