AEK-MOT-TK200G1 SPC5-UDESTK - No JTAG client found !
pivic
I have been trying to connect to the AEK-MOT-TK200G1 using a SPC5-UDESTK.
I tried UDE starter kit 5.02.04, and UDE starter kit 2021.05.
I'm getting the following error: (Message from component 'PpcJtagTargIntf' :Can't connect target !)
I have checked all drivers and versions but I still get the same error.
Here is my device manager:
 I ran out of ideas of what to try next.
Has anyone got this setup working?
Thanks,
Alex
Max VIZZINI
Did you put the board in SW debug mode?
Check User Manual UM2995 at paragraph 3.5
 https://www.st.com/resource/en/user_manual/um2995-getting-started-with-the-aekmottk200g1-evaluation-board-for-car-opening-closing-systems-stmicroelectronics.pdf
General info about debugging with PLS UDE can be found here:
Part 7 - AutoDevKit™ detailed tutorial: Debug and release of firmware created with AutoDevKit™
Some more trouble shooting hints from the Community:
PLS UDE and Windows 10 - STMicroelectronics Community
Best Regards,
AutoDevKit Team
3 REPLIES 3
Max VIZZINI
Best Regards,
AutoDevKit Team
Thank you for your reply.
I have tried all the suggestions.
1. I placed JP2, applied power, removed JP2, connected the SPC5-UDESTK -> same error.
2. I watched the video, and that is what I'm doing. I also have the AEK MCU board, and connecting to the onboard debugger works fine. But it doesn't work when I use the SPC5-UDESTK to the AEK-MOT-TK200G1 board.
3. I uninstalled the drivers and reinstalled them -> same error.
I don't know what else I can try..
Thanks,
Alex
Out of nowhere, today it worked on both computers that I was using...
Without changing anything on them, it suddenly worked. I can now flash the board and step by step the code.
I don't know what was wrong before.
Thanks for your help,
Alex
