When TDA7577 disables I2C mode, how to clear the fault through hardware control and restore to normal operation state?
Tliu.3
0693W00000GW0TuQAL.pngTDA7577, PIN16 pin is left floating to disable I2C bus mode, the speaker short-circuit fault is detected, PIN14-CD_OUT output is permanently low, and the fault still exists after power-on again, and the speaker is in no sound output protection state. May I ask TDA7577 in the I2C disabled mode, How to clear faults through hardware control and restore normal operation?
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
0 REPLIES 0
