Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
alarm and sound
Hello.I would like to do the following but since I don't have the necessary skills I ask you. If possible, I prefer to control everything with the keys.I make a list of the functions that I would like to implement:ALARM SECTION- wake up in the mornin...
arivel1 by Associate II
  • 3151 Views
  • 6 replies
I am using Steval-mksbox1v1. I need a sample code or standard library , application notes and programming manual for Microphone TS922EIJT and MP23ABS1TR
How to configure ADC in STEVAL - MKSBOX1v1 (With DMA or W/o DMA)How are the setting to be used for this board. (Clock dividing by ?) - For Audio it will be single channel continuous scanThere are two pins in STEVAL - MKSBOX1V1 MREF and M1P what shoul...
