2016-07-17 11:34 PM
Hello there,
I have a question regarding TSC101 amplifier. Will it work if current will flow through the sense resistor in a reverse direction? I was wondering either it is possible to use it like this:https://dl.dropboxusercontent.com/u/14154631/Zrzut%20ekranu%202016-07-18%2008.32.00.png
Instead of a classic high side sensing configuration like in the datasheet. I would appreciate all help.2016-09-15 09:28 AM
2016-09-16 12:49 AM
Actually, the TSC101 is a mono directional amplifier, so it won't give any current indication if current flows in the opposite direction (output voltage of TSC101 is clamped to zero in this case).Best regards,Anthony Boimond
