STA333 and APW questions...
alfsch
Posted on July 20, 2014 at 18:04
Hello, first : can i use STA333 with filterless output (only snubber) ? (and sound quality ...better , than with filter ?)
and in the APW gui, i cannot import speaker response (F5) - not working; is this only working, when active STA is connect or ..when ?
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
4 REPLIES 4
Nickname1623_O
Posted on July 21, 2014 at 09:06
hi Schaub ,
yes , you can use STA333BW with filter less configuration , but please pay attention for load type , an inductive load or speaker is mandatory for filter less application .
Actually external LC filter had been used to filter out high frequency carrier that will create EMI issue , then shorter speaker wire and lower supply voltage/output power will help to reduce radiation from PWM output signal.
regarding APWorkbench speaker tuning feature , it will be actived after you got key .
did you register APWorkbench ?
by the way , we have a dedicated forum for APWorkbench, you may find more info there.
alfsch
Posted on July 21, 2014 at 18:28
Thanks for fast response.
- and no, APW has no key - i didnt know this (where is info about ?)
and how to register APW ??
best regards,  Alfred
Nickname1623_O
Posted on July 22, 2014 at 05:13
hi Alfred,
regarding APWorkbench registration , you may find info in below link
[DEAD LINK /public/STe2ecommunities/analog/Lists/APWorkbench/AllItems.aspx]https://my.st.com/public/STe2ecommunities/analog/Lists/APWorkbench/AllItems.aspx
alfsch
Posted on July 24, 2014 at 12:45
Hello again,
can you help me about register APW , because i wrote moderator in APW-area two times now, but got no answer until now; so...how to do ?
best regards
Alfred
