Simple audio recorder solution selection
Options
2015-12-03 1:51 AM
Posted on December 03, 2015 at 10:51
Hi, All!
Could you please recommend audio amplifiers solution for mono recorder / player with following characteristics:- electret mic
- dinamic speaker 0.3W
- power voltage 3.0V
- shutdown possibility is neccessary
- not so expensive
- will be used with STM32F3 12bit ADC & DAC for recording short voice tags to waypoints
Currently I'm looking for TS472 mic preamp and class-D or AB BTL speaker amp. Might is be a better solution?
BTW, is it possible to contol TS472 gain by MCU? Or add a limiter?
Labels:
Audio Amplifiers
1 REPLY 1
Options
2015-12-03 6:06 AM
Posted on December 03, 2015 at 15:06 hi Dmitr, TS472 gain setting can be controlled by MCU with different I/O .for more info you may check AN2240 in ST website. and for audio amplifier you can consider TS4871 . thanks to consider ST device YT
