TDA7266M
Options
‎2015-12-14 10:37 PM
Posted on December 15, 2015 at 07:37
We have chosen TDA7266M 7W Mono amplifier for our new project with out Micro controller interface. As per datasheet recommenced test circuit (Figure 3a: Stand-alone Low-cost Application.) i have assembled & test the circuit with common VS & VCC 12V DC and VS5V & VCC12V. but no response of the output speaker (8Ohm 10W). If i missing any thing Please suggest me Thank You
Labels:
- Labels:
Audio Amplifiers
Options
‎2015-12-14 11:14 PM
Posted on December 15, 2015 at 08:14 hi Panneerr , for TDA7266M with stand alone configuration , if you provided power supply and audio input , you should get speaker output . so please check the voltage level of standby and mute pin . Thanks YT
Options
‎2015-12-16 9:34 PM
Posted on December 17, 2015 at 06:34
Hi Zhao yun tao,
Thank you for your support, I have provided input signal from my mobile audio out point & 12VDC gave from DC power supply. As per datasheet mentioned VTMute max, 4.1V and VTST-BY max. 1.8V. If i connect common VCC & VS 12V and Mute & St-by connected with 47K+47K divider resistor, so it’s have 6V input, Is there any issue to connect greater than Max. Volt to Mute & St-by Pins?Note: I have tested with separate power also (VCC=12V; Vs=5V) but no response
S-GND, PW-GND was common How to check the TDA7266M IC working status? (Tested continuity between GND & VCC also, No short)Please suggest
Thank you, Panneerrajan
