How to import a project ?
DYann.1
Senior II
I found this link on the internet : https://github.com/logical/sgtl5000-stm42f4
But when i download and try to open it under STM32CubeIDE, I encounter errors such as this window.
Do you know how to convert to a correct format under STM32CubeIDE ? Thank you for your advice.
Regards.
11 REPLIES 11
DYann.1
Senior II
Here, you can find the project I don't know if it can open with STM32Cube IDE but I guess so. Thank you for your helps.
Pavel A.
The original project looks like for SW4STM32. Try to import is as SWSTM32.
DYann.1
Senior II
Import under STM32Cube IDE ?
I have nothing about SWSTM32, do I have to download dedicated software for this project ?
Pavel A.
Yes. In that menu, select "import acv6 System Workbench.... project"
But, it's not complete, a lot of things are missing, for example the .ioc file
Probably I didn't do the right import method, I can't compile the project also.
Your RAR file doesn't include the whole project, just a few files. No chance of it working like that.
I couldn't get it to work either. You can always create a new project for the appropriate chip then replace all the files with the ones in your project.
Sorry, in this forum I can't send a ZIP file (which contains all the files) and I converted the ZIP file to RAR online. That why missing files.
Pavel A.
Why won't you contact the author of the github project. He may be glad to help.
