Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
Resolved! Distortion of TDA7297 at 40kHz~80kHz
Hello, I would like to know the distortion of TDA7297 at 40kHz~80kHz. If it's distortion may over 1%, please give some alternatives. Thanks.Reference: https://www.st.com/resource/en/datasheet/tda7297.pdf
Mark_You by Associate
  • 2632 Views
Sampling simultaneously 8 analog microphones with ADC120
Hi All,Could you please advice. Does ADC120 support simultaneous sampling of 8 channels? Can i connect to it 8 IMP23ABSU Analogue MEMS microphones, sample acoustic signals from all microphones for further processing in DSP?
Levan by Associate III
  • 1775 Views
  • 2 kudos
AUDIO RECORD
Hello,I would like to know how to record sound through microphone. I have a STM32L552E-EVAL evaluation board and I have a example provided with this card 'Demo' but after reading the recommendations I still cannot record sound via the headphones prov...
DYann.1 by Senior II
  • 1334 Views
TDA7563B DD (POwerSO36)
The original TDA7563BDD is replaced by TDA7563BPD. What is the upgrade after the upgrade? Please explain in detail. Thanks. Maybe we can replace the chip with a better one. Any recommendations? Not afraid of expensive. Just as long as it's good.
hke.1 by Associate II
  • 2792 Views
  • 6 replies
Resolved! Unknown IC
To whom it may concern, I have an IC, two diiferent IC's in fact, in my hand and it was hard to figure out what they are, their function, or any tech info. I would kindly like to ask for tech feedback, instruction, ie any information you can provide....
radara by Associate
  • 4815 Views
  • 1 replies
How to import a project ?
Hello,I found this link on the internet : https://github.com/logical/sgtl5000-stm42f4But when i download and try to open it under STM32CubeIDE, I encounter errors such as this window.Do you know how to convert to a correct format under STM32CubeIDE ?...
  • 4527 Views
  • 11 replies
TDA7498 application schematics dillemas
Dear sir,madam, I have a questions about schematics in figure 3 of TDA7498s datasheet:- should pin PGND (18) be left unconnected to ground?- pin VSS (36) is also left unconnected to ground or it is on potential (VCC - 3.3 V)?- are SUB_GND(1) and for ...
