2021-09-13 11:49 PM
2021-09-14 12:14 AM
If you mean the audio.bin file: It's just a WAV file that has been renamed to BIN.
There are plenty of tools on the net that can be used to convert binary data to HEX, e.g. srecord.
/Peter
2021-09-14 12:14 AM
/Peter
2021-09-14 12:18 AM
Thank You, @Peter BENSCH Sir.
2021-09-14 9:46 AM
The .WAV file is in a binary form, would suggest you look at the internals with a file viewer / hex editor type tool to understand the nature of the file and its content.
