Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
Can't set SPIRIT1 status to lock Tx or Rx
I have been using STEVAL-IKR002V4D (a daughterboard with SPIRIT1 868 Mhz transceiver) to transmit data. I have it hooked with Raspberry Pi. I have followed the driver library example provided in the design kit software. However, I can't initialize th...
RPink.1 by Associate
  • 797 Views
  • 0 replies
LM2901 : Common mode input voltage range.
What will happen with output when input signal is out of "Common mode input voltage range"?Ex.) Vcc=5V (Vicm= 0 to 3.5V) ---> Input IN-=0V, IN+=4V signals Then, Output go to 5V(saturated)?
RKama.3 by Associate
  • 902 Views
  • 1 replies
