Hi ST Community, I found an audio.bin file in SAI example. I want to have my own .wav file's .bin file. So, i need help in converting audio files to .bin or hex format.
Vins
Senior
Peter BENSCH
If you mean the audio.bin file: It's just a WAV file that has been renamed to BIN.
There are plenty of tools on the net that can be used to convert binary data to HEX, e.g. srecord.
/Peter
3 REPLIES 3
Peter BENSCH
/Peter
Vins
Senior
Thank You, @Peter BENSCH​  Sir.
The .WAV file is in a binary form, would suggest you look at the internals with a file viewer / hex editor type tool to understand the nature of the file and its content.
