2023-03-13 02:51 PM
I am trying to identify a chip with an ST marking. It is an SOIC-14 and appears to be identified with the markings 247. There are more markings on the package, but they vary from package to package and I suspect they are some sort of manufacturing and/or date code.
Based on the circuit the IC was found in I believe it's some sort of audio processor or transceiver.
2023-03-13 03:31 PM
Welcome, @TChri.3, to the community!
It is the LF247DT, a quad JFET opamp.
Does it answer your question?
/Peter
2023-03-13 03:31 PM
/Peter
2023-03-13 04:05 PM
Hi @Peter BENSCH
Yes, this is exactly the info we were looking for.
Thanks!
2023-03-13 04:22 PM
Great!
If the problem is solved, please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
/Peter
2023-10-29 12:42 AM
Hi Peter, could you please explain how did you know the answer so that we can do it too? thanks.
2023-11-01 03:07 AM
Well, this is knowledge that I have gathered over the past decades. I am happy to help with further questions of a similar nature, but I cannot guarantee it.
