2023-01-10 11:39 AM
Could you explain me what is the "input Current" named in the figure 5 compare to the input bias current and input offset current?
Thanks,
Lucie
2023-06-06 8:50 AM
This curve shows the input bias current. Which is the average current getting out of the input pins.
Iib=(Iib+ + Iib-)/2. (when the op amp is used in linear, not as a comparator)
The input offset current is the difference between the current off the two inputs. Iio=Iib+ - Iib-
Best Regards,
Pierre
