Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
Resolved! SPICE model for OA1ZHA
Hello,​I want to perform AC analysis using LT Spice. I tried to find SPICE model for op-amp OA1ZHA but could not reach it. I would appreciate it if you told me how.Best,H. Sawano
HSawa.2 by Associate
  • 1449 Views
TSC210 current leak path into VREF when IC has no VCC
There is a leak path between IN+ and VREF, through the feedback resistors when VREF is connected to GND.I need to know whether this path is still possible when the IC has no VCC applied to it.I disable the IC to save power consumption but if this pat...
JDLR by Associate
  • 880 Views
  • 1 replies
How to make voltage offset measurements for TSC2012
I am trying to confirm a series of electrical measurements of the TSC2012H and have been successful in measuring positive and negative input bias current and both high and low voltage output swings, however have been unable to make the Voltage offset...
JVoeg.1 by Associate
  • 1072 Views
  • 1 replies
Explanation on FFX and DDX and comparision to PWM.
Hello,we plan to design a fully digital Class-D audio amplifier based on STA309A/STA311B and STA516BE, STA516B, STA510A, STA510F.Datasheets of the related parts use the terms "DDX" and "FFX". But I can found nowhere any explanation what thet technolo...
ARump.2 by Associate
  • 1624 Views
  • 0 replies
