Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
Resolved! Interfacing 32V analog signal with STM32
I need a help. I want to interface 32nos of 32V Analog signals with microcontroller. i also need Ethernet connectivity. I've selected STM32F746ZGTx controller for my application. I want to know the industrial way for to interface these higher voltage...
SSona.11 by Associate
  • 2869 Views
  • 1 replies
Random fault on TDA7492's 3.3V embedded VDDS regulator
We are using TDA7492 since 2013 on some different design, and up to few months ago everything was ok. But recently we have random faults on VDDS regulator. Currently the percentage of failures, all of the same type, is 5%. Too high for us. In all our...
SBond.2 by Associate
  • 876 Views
  • 0 replies
Minimum interface pins required for proper operation of STPM32 ?
Hello, I am using STPM 32 for my metering application and UART interface to communicate with MCU. I am using optocouplers for isolation between analog STPM32 and digital uC section. In the datasheet, it has given that pins like EN, SYS and SCS shoul...
OInam by Associate II
  • 652 Views
  • 0 replies
Resolved! Date code on TL084IDT.
Hi, trying to decode the date code on some TL084IDT SO14. Can not find anything in the data sheets or other product documentation.The two codes are: MZ15808 and MZ9Y823.
JSalm.1 by Associate
  • 1597 Views
  • 1422 Views
  • 0 replies
