Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
TDA7266M max input voltage
What is the max signal input voltage for the TDA7266M? We will be trying to merge a tube preamplifier with a 7266 power amp to make a small guitar amplifier. We can always shunt input signal voltage with a zener as the tube pre has a fairly large ou...
SMoor.2 by Associate
  • 1003 Views
  • 1 replies
how to configure sta510f output 4 independent channels, instead of 2 - Channel Bridge, thank you!
I now use sta311b+sta510f, how to configure sta510f output 4 independent channels, instead of 2 - Channel Bridge,Or how to make sta311b in each channel PWM output full  PWM not half PWM, I can only get half the signal, bridge is not a problem TKS!
0xfdr by Associate
  • 743 Views
  • 0 replies
I2S channel digital mems microphone sound level meter
Hello, I'm trying to measure the ambient noise level in decibels (dB) using the I2S channel for a project. I am novice at stm32 microprocessors. I just want to measure the noise level of the environment. Can you help me? Can you send me a sample proj...
mcizmeci by Associate II
  • 995 Views
  • 0 replies
How to send ADC data from memory to USB at high speed?
Hello community,I have been using Nucleo F413ZH for some time. So far I have used ADC for lower speeds and needed nothing more to read the data than STMstudio. Recently I have a problem that I don't know how to approach. I also don't know how to find...
KWalc.1 by Associate
  • 1152 Views
  • 0 replies
Low pass filter on ongoing samples.
Hi all,My application requires to sample a sensor and send the samples out in real time, without saving the samples.I am required to run a low pass filter on the samples, but here is the problem cause if I want to do it on 20 samples for example then...
JKhal by Associate III
  • 3278 Views
  • 1 replies
How to pass 10 arrays simultaneously in a for loop?
Hello everyone,I am trying to get data from 10 ADC channels and want to display all the data simultaneously on the LCD. I successfully get the data from ADC channels but unable to display it simultaneously .Please give me suggestions over it and i am...
Mohan1 by Associate III
  • 2258 Views
  • 4 replies
