Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
ST7580 - PLM01 DC Question
I'm speaking about the X-Nucle-PLM01A1 Board that uses the ST7580 IC. I would like to use this IC in a DC Bus application, not AC Line, like most of the reference design does. On page 13 of UM2189 is shown how the boards are connected. My question is...
Problems using PDM To PDM
Dear fellow Devs,I got a problem using the PDM to PCM library. While it seems to be working fine for a single conversion. There seems to be some kind of gap and noise between the results.The picture below shows a 440Hz sine wave.The class i wrote loo...
Resolved! TDA7266 instead TDA7266M
I need to fix an audio amplifier that uses a TDA7266M. Unfortunately, I can only find TDA7266 (stereo version) in stores in my city. I compared the pins and it seems that I can use one channel without any modifications. What should I do with a discon...
OIsai.1 by Associate
  • 2095 Views
  • 3 replies
MA pointers pointing to something else when sampling audio.
Im trying to build a guitar pedal on a STM32F446RE. 'SoundIN' is assigned to a pointer that is assigned to address value of the adc samples. 'SoundOUT' is half of soundIN (Just a test to see if works). However, output pointer '*outPoint' is showing a...
_legacyfs_online_stmicro_images_0693W00000bhsh3QAA.png _legacyfs_online_stmicro_images_0693W00000bhsiBQAQ.png
JRatt.2 by Associate II
  • 2885 Views
  • 4 replies
