Analog of ST AMP TDF1778
AB.19
Can't find any documentation for this op amp. Someone can tell you where to get it, as well as a possible analogue? Thank!
3 REPLIES 3
Peter BENSCH
It is/was not an opamp but a dual 2amps high side driver, which has been made obsolete many years ago.
The data sheet can easily be found on the Internet using your preferred search engine.
Good luck!
/Peter
Thank! I have already found the documentation, but what about analogs from ST, if something with direct compatibility of pins?
Peter BENSCH
Sorry, there is no replacement available, neither pin nor functional compatible.
/Peter
