2024-04-18 6:59 PM - last edited on 2024-04-19 1:08 AM by Peter BENSCH
I would like to know where the configuration set in STVP is stored.
I'd like to set the configuration automatically, but I don't know where the default storage address is.
2024-04-29 3:33 PM
The STVP settings are saved in the Windows registry, branch:
[HKEY_CURRENT_USER\SOFTWARE\STMicroelectronics\STVP]
Hope that helps?
/Peter
2024-04-19 1:10 AM
What do you mean with default storage address?
2024-04-21 9:27 PM
This is a question about where the Hardware/Port/Programming mode/Device values set in STVP configuration are stroed.
so that it can be read through the command.
2024-04-29 3:33 PM
Hope that helps?
/Peter
