Where is VREFINT_Factory_CONV?
juvf
I have STM8L051.
In the RM
The internal reference voltage is factory measured and the result of the ADC conversion is
stored in a specific data address: the VREFINT_Factory_CONV byte represents the LSB of
the VREFINT 12-bit ADC conversion result while the MSB have a fixed value: 0x6.
In what document can I find the address of the VREFINT_Factory_CONV register?
9 REPLIES 9
juvf
Is there anybody here? Is the developers of the processor here? Where is VREFINT_Factory_CONV?
juvf
up
dmeneghine
microcontrollers value line does not have VREFINT_Factory_CONV, see the data sheet of the stm8l151 "memory map" 0x00 4910
-- Daniel
juvf
I do not understand. Does the STM8L051 have no VREFINT_Factory_CONV or does the STM8L051 have a VREFINT_Factory_CONV at 0x4910?
dmeneghine
The STM8L051 have NO VREFINT_Factory_CONV because it is value line.
The STM8L151 have a VREFINT_Factory_CONV at 0x4910?
juvf
I can see RM0031 Reference manual STM8L051/L052 Value Line
14.3.17 Internal reference voltage conversion
The internal reference voltage is internally connected to the V REFINT channel. This analog
input channel is used to convert the internal reference voltage into a digital value.
The VREFINTON bit in the ADC_TRIGR1 register must be set to enable the internal
reference voltage. This reference voltage must be enabled only if its conversion is required.
it doesn't say, that the STM8L051 have NO VREFINT_Factory_CONV because it is value line.
If the STM8L051 have NO VREFINT_Factory_CONV, then what is the voltage value of the internal reference in STM8L051?
juvf
up
How to ask the question to the developers of the processor (STM8L051/L052)?
juvf
up
juvf
up
