.text size overflow (1581) - cosmic
Options
‎2011-08-29 6:26 AM
Posted on August 29, 2011 at 15:26
Hi Everybody,
I have some problem with my linker, and I don't know how to fix it. Can somebody help?? I'm new to this. Running Linker clnk -l''C:\Program Files (x86)\STMicroelectronics\STM8S_StdPeriph_Lib_V2.0.0\Libraries\STM8S_StdPeriph_Driver\src'' -o debug\stm8s103.sm8 -l''..\..\..\..\..\program files\cosmic\cxstm8_16k\lib'' -l''..\..\..\..\..\..\program files (x86)\cosmic\cxstm8_16k\lib'' -mdebug\stm8s103.map debug\stm8s103.lkf &sharperror clnk debug\stm8s103.lkf:1 segment .text size overflow (1581) The command: ''clnk -l''C:\Program Files (x86)\STMicroelectronics\STM8S_StdPeriph_Lib_V2.0.0\Libraries\STM8S_StdPeriph_Driver\src'' -o debug\stm8s103.sm8 -l''..\..\..\..\..\program files\cosmic\cxstm8_16k\lib'' -l''..\..\..\..\..\..\program files (x86)\cosmic\cxstm8_16k\lib'' -mdebug\stm8s103.map debug\stm8s103.lkf '' has failed, the returned value is: 1 exit code=1. stm8s103.elf - 2 error(s), 0 warning(s)All fixed now, silly me. :D
#size-overflow
3 REPLIES 3
Options
‎2012-02-15 8:29 AM
Posted on February 15, 2012 at 17:29 Someone can help?
Options
‎2012-05-09 6:38 AM
Posted on May 09, 2012 at 15:38
I'm having the same problem. What exactly did you do to correct it.
Options
‎2012-05-29 9:15 AM
Posted on May 29, 2012 at 18:15
Read my message, the problem is cosmic compiler
[DEAD LINK /public/STe2ecommunities/mcu/Lists/STM8Discovery/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM8Discovery/Cosmic or the worse compilatorlinker ever programmed&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580004008F0975979A844820611B699DF2ED1&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/STM8Discovery/AllItems.aspx¤tviews=0] https://my.st.com/public/STe2ecommunities/mcu/Lists/STM8Discovery/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fSTM8Discovery%2fCosmic%20or%20the%20worse%20compilatorlinker%20ever%20programmed&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580004008F0975979A844820611B699DF2ED1...
