2014-03-27 10:04 AM
I am timing the ADC conversion from TRGO to EOC. I calculate that the conversion should take 3.5us but I measure a minimum of 4.0us using an oscilloscope.
I have included the relevant code loop below.Please does anyone know where the extra time is coming from? My application requires close coordination of the ADC with external signals. //////////////////////////////////////////////////////////TRGO = TIM1 CH4 = (counter=0x01)
ADC clk = 4MHz
conversion = 14 clocks / 4Mhz = 3.5us
measured: 4.0us (minimum) between toggles
////////////////////////////////////////////////while(!(GPIOC->IDR & 0x08)){} // wait for pwm sig high (counter=x)
for (tempi=0; tempi<5000;tempi++)
while(GPIOC->IDR & 0x08){} // wait for pwm sig low (counter=0)
GPIOB->ODR ^= 0x80; // toggle pin
ADC1->CSR = 0x00;
/ clr EOC (@ top of loop to catch 1st pass)while(!(ADC1->CSR & 0x80)) {} // wait for ADC completion
while(!(GPIOC->IDR & 0x08)){} // wait for pwm sig high (cntr=x)
