2016-06-02 03:44 AM
I'm trying to use the ST Visual Develop with the Cosmic st8 32k compiler. I install everything and build the project. That all works fine. When I try to connect to the Discovery board with the debugger using Swim ST-link, I receive the following error:
Failed to connect target.Starting debug session... -> Emulator reset (usb://usb)... ** Connection error (usb://usb): swim error [30200]: st-link connection error -> Failed to connect target.
