STM8 Opcode Map
lloydb
Attached is based on PM0044 'STM8 CPU programming manual' Doc ID 13590 Rev 3, 2011-09.
LibreOffice Calc workbook with five sheets:
  • 1st Byte - instructions with no pre-code (i.e. opcode is one byte) or whose first byte is a pre-code (i.e. opcode is two bytes)
  • (1st Byte = PWSP), 2nd Byte - second byte of instructions whose first byte is PWSP pre-code
  • (1st Byte = PDY), 2nd Byte - second byte of instructions whose first byte is PDY pre-code
  • (1st Byte = PIY), 2nd Byte - second byte of instruction whose first byte is PIY pre-code
  • (1st Byte = PIX), 2nd Byte - second byte of instructions whose first byte is PIX pre-code
0 REPLIES 0
