ST VD Software installation Issue : An anomaly (1) has been detected during installation.
Anand Kumar
Hi Team,
I have installed ST Visual Develop in ST web page. At the end of installation, installation page got stuck and then i have terminated by end task using task bar....
After completion of installation, i have opened software then following error message has occurred as shown in figure "while_opening". and exit from IDE as shown as "while closing".
In IDE --> help ---> Generate support file... pl find the file support file.....
Please guide me to solve this issue soon....
Thanks & Regards,
Anand Kumar.
10 REPLIES 10
Mahendra
Based on my experience, if you install the STVD in Program Files or Program Files (x86) , then you have to run the STVD by run as administrator. After that, the error while_closing image does not appear again.
if you want to run the STVD as administrator quickly, you can follow this rules.
https://www.makeuseof.com/tag/always-run-apps-administrator-windows/
you can do the same steps with STVD. Thank you.
mahendra
