2014-08-01 3:09 AM
I'm using STVD+cosmic compiler and STM8s-discovery board, i test a little bit and go away for a long time.
After i change the new computer and install STVD, cosmic,plug the USB cable to board , the board running fine.I open project ''PWM'' from example, compile with out error, can debug but the 'run' menu is diabled, what's wrong ?2014-08-04 3:22 AM
It can do now, first, Start to debug, and follow by run command.
