2010-04-22 01:35 AM
Hi all,
just a link to the stuffs I made based on discovery kit. I used the kit to upgrade my 4 channels radio transmitter to generate a 7 channels transmitter with mixing capabilities. Configuration is created with a python script on PC and uploaded into flash with the STLink. Source code is provided as is at your own risk. I put also some simple examples. This site is under construction and I will try to update it quite often. Next main project is to make a 2.4ghz transmitter/receiver. Hope it will help. Regards, Xavier2010-05-09 06:09 AM
Hi
I have nearly finished my 2.4GHZ transmitter based on STM8S discovery kit: Xavier
