2009-04-21 7:06 PM
need help--STM8A bootload
2011-05-17 6:02 AM
hello:
Is there anyone ccould give me some example of STM8A bootload source code? My boss hope me make MCU code can be updated from CPU I2C... best regards! wolver 2009-4-21 [ This message was edited by: wolver on 21-04-2009 07:09 ]2011-05-17 6:02 AM
Hi Wolver,
You can refer to this application note: AN2737: ''Basic in-application programming example using the STM8 I2C and SPI peripherals'' available on the following link: http://www.st.com/stonline/products/literature/anp/14584.pdf Regards mozra2011-05-17 6:02 AM
Hi mozra
Yes, I have seen that pdf, But I still can not find right way to home... Any other document? thanks a lot! Regards wolver2011-05-17 6:02 AM
Hi Wolver,
You can refer to this document: AN2659: ''STM8S in-application programming (IAP)using a customized bootloader'' it can help you :D http://www.st.com/mcu/modules.php?name=mcu&file=familiesdocs&FAM=113 Regards mozra2011-05-17 6:02 AM
Hi mozra
Great thanks! You are a enthusiastical man. I think I can try to go home now... By the way, This forumsit login from China is too slowly... best regards wolver [ This message was edited by: wolver on 22-04-2009 07:45 ]
