my problem is stvd and compile with st assembler linker
mahdi honarvar
Posted on March 25, 2017 at 09:38
Hello. I want compile a simple program that is :
stm8/
segment 'rom'
PD_ODR EQU $500F
PD_DDR EQU $5011
PD_CR1 EQU $5012
bset PD_DDR,#6
bset PD_CR1,#6
loop2
bset pd_odr,#6
bres pd_odr,#6
jp loop2
end
when I compile this program Stvd get a lot of error that is :
can any one help me??
my windows is 7 and 64bit and I use from STVD and st assembler linker.
5 REPLIES 5
Arlet Ottens
Posted on March 25, 2017 at 12:24
You need to start your lines with spaces or tabs, otherwise the assembler assumes you're defining a label.  Like so:
stm8/
    segment 'rom'
PD_ODR EQU $500F
PD_DDR EQU $5011
PD_CR1 EQU $5012
    bset PD_DDR,#6
   bset PD_CR1,#6
loop2
   bset PD_ODR,#6
   bres PD_ODR,#6
   jp loop2
   end
Posted on March 25, 2017 at 23:24
Exactly. Thank you very much. can you help me about simulating?? when I build the program and press the start Debug I think I should press step into but when I press step into I don't see any change in simulating.if you have a video about simulating can you send me ?? thank you
Posted on March 25, 2017 at 23:26
I don't know. I've never used the simulation.
Posted on March 26, 2017 at 07:50
So how you test your program??
Posted on March 26, 2017 at 08:36
Load it in the device.
