Meaning of Cosmic's segment .bss size overflow error
Workalot
Posted on December 05, 2010 at 08:02
3 REPLIES 3
luca239955_stm1_st
Senior II
Posted on May 17, 2011 at 15:11
1744 is the size of the overflow, that is, the difference between the actual size of the segment and its maximum size (as specified by the -m parameter for that segment, in the linker file)
As for your other question, I quote the user manual, page 9:
The COSMIC compiler defines the __CSMC__ preprocessor symbol....
Luca
PS: note that when you have a linker error the map file is NOT created.
Workalot
Thank you, and succinct.
The page 9 reference (I had read it) escaped my understanding as to its ability to discern the Cosmic compiler.  Perhaps a mention could be included in the manual?
Andrew Neil
Evangelist III
''The page 9 reference (I had read it) escaped my understanding as to its ability to discern the Cosmic compiler.''
It seems pretty clear to me - in what way would you have it changed?
''Perhaps a mention could be included in the manual?''
Which manual do you mean?
Since the Standard Peripheral Library supports both Cosmic & Raisonance compilers, its source code would seem like an obvious place to look to see how it distinguishes the two; eg, in stm8s.h:
/*                   Library configuration section                            */
/* Check the used compiler */
#if defined(__CSMC__)
 #undef _RAISONANCE_
 #define _COSMIC_
 #define TINY @tiny
 #define NEAR @near
#elif defined(__RCST7__)
 #undef _COSMIC_
 #define _RAISONANCE_
 #define TINY page0
 #define NEAR data
#else
 #error ''Unsupported Compiler!''          /* Compiler defines not found */
#endif
