machine cycles - for instruction
fagundesbr
Posted on July 16, 2015 at 17:05
hi there!
i´m using the Cosmic c compiler and STM8S microcontroller.
i can´t find this information:
how many machine cylces this function takes?
for(conta=0;conta<10;conta++);
it´s seem to me that the ''for'' takes 6 cycles in simulator, but i want to be sure about that.
sincerely;
luca239955_stm1_st
Senior II
Posted on July 20, 2015 at 12:24
you have to split your problem in two parts:
1) see what assembler is generated for your C Code
2) measure the cycles for the assembler
If you have measured 6 cycles for a for loop of 10 iterations either your measure is wrong or the loop was just optimized away.
Hope it helps.
Luca
