How to reset MCU through SWIM and command line
senayati
Posted on April 22, 2010 at 01:34
senayati
Posted on May 17, 2011 at 15:08
Stefan,
Thank you for your reply. The solution you offered worked fine and it is just what I wanted. Thanks again
Sia Enayati
sramsauer9
You can use gdb7.exe to restart mcu after programming.
I use the following command line:
gdb7.exe --quiet --command=restart_mcu.ini
Content of restart_mcu.ini
<-----------schnipp------------->
# define emulator reset port and MCU
define emulator-reset-port-mcu
target gdi -dll swim\stm_swim.dll -stlink3 -port $arg0 -mcuname $arg1
mcuname -set $arg1
end
# reset command and quit
emulator-reset-port-mcu usb://usb stm8s105c6
quit
<-----------schnapp------------->
You have to replace the mcu type (here stm8s105c6) to the one you are using.
Stefan
